Exterior trim clips? Source
swing69
fightin' socialism
Central Socialist NJ
I need clips for the rear qtr top trim and the door top edge trim. Sources??? Thanks
Yes I have a fastenal. Count? I missing a few on each piece, as the wire mount rotted away. OR are you asking for totals?
Mike
Start a wanted thread. Someone may have some for you.
Yes, I sent every one that was in the pic and i believe they were all the same coming off 65 Valiant side trim
Yes, I sent everyone that was in the pic and I believe they were all the same coming off 65 Valiant side trim
Ok if that is the case @swing69 I can send you some when they arrive to me. See pic below for what 65 Dartman sent in the mail to me. Let me know how many you need.
Cheers,
Jack
@65 Dartman Are these the ones you sent me? In the one picture they look a little similar. If so I could send some his way depending on how many he needs.
the top of quarter panel clips are probably very similar. The top of door trim clips are different, which I have
Hi Bob and Jack. I still need to get to the school shop and get the clip count. It’s been tough to get in with school building and shut downs. I WILL get there this a Thursday (1/28). Thanks. MikeA
