I will send you a DM and get your phone number, thanks for reaching out good to know local spots here!Bring it to our Machine shop in Danielsville to get cut.. Its looks to be a cast crank flywheel. If the engine was replaced with a steel crank it may be the wrong flywheel for the engine. You will have to make sure it is a steel or cast crank. Or you will have a balance issue. Did it vibrate? I have flywheels here.
