1. Ron816
    Ron816 Well-Known Member
    230
    147
    Nov 15, 2019
    Quincy, MA
    Local Time:
    6:36 PM
    Installed a new factory mopar clutch from Brewers Performance, I have extreme shudder upon take off to a point that the rear wheels hop violently, removed inspection cover and noticed that the pressure plate was hitting the starter boss, I contacted Brewers and they said they have run into this once in awhile, the boss on some early bellhousings are larger they told me to either relieve the boss or the pressure plate, my question is would the plate hitting the boss cause the shudder?,
  2. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    44,981
    12564
    Oct 14, 2010
    Idaho
    Local Time:
    3:36 PM
    I would say "no" unless you have some problem related. Hell once I saw a guy got a Great Big piece of grit between the flywheel and crank and cocked the flywheel
    Chatter......poor choice of clutch material, that is using some non-sprung agressive race disk in a street app, damaged spring assembly in the hub, oil on the disk, loose motor mounts, or something in the clutch linkage. Could even be some unforseen play in the rear suspension. I would guess it could be a defect / mechanical problem in the pressure plate assembly, but I would call that one "rare."
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • Professor Fate
      Professor Fate Push the button, Max...
      1,021
      1283
      Jan 13, 2020
      Wisconsin
      Local Time:
      5:36 PM
      What is the condition of your flywheel? New/used/resurfaced? A new disk on a used, worn, glazed, unresurfaced flywheel is also a recipe for the exact problem you're experiencing.
      • Agree Agree x 3
      • inertia
        inertia Well-Known Member
        3,323
        585
        Feb 4, 2011
        Victoria B.C. Canada
        Local Time:
        3:36 PM
        Did you have the flywheel resurfaced ?
        If not,. That'd be my first move.
        • Agree Agree x 2
        • RammerJammer75
          RammerJammer75 Well-Known Member
          460
          585
          Aug 28, 2020
          Kingsport, TN
          Local Time:
          6:36 PM
          I would think if the pressure plate is hitting the starter boss, you would hear that constantly. I don't see how it could cause your shuddering issue, but I could be off the mark there.
        • Ron816
          230
          147
          Nov 15, 2019
          Quincy, MA
          Local Time:
          6:36 PM
          New disk, new pressure plate, new flywheel, new throw out bearing
        • rklein383
          rklein383 Well-Known Member
          1,556
          471
          Dec 2, 2005
          Local Time:
          5:36 PM
          Last time I had clutch chatter, it was a bent disc that was the cause.
        • dano
          dano Evil Handy Man
          3,312
          1194
          Aug 22, 2005
          Gresham, Oregon
          Local Time:
          3:36 PM
          Bottom line if it's making contact you need to clearance it. I wouldn't trim the pressure plate.
          • Agree Agree x 2
          • Like Like x 1
          • 67Dart273
            44,981
            12564
            Oct 14, 2010
            Idaho
            Local Time:
            3:36 PM
            ^THIS^ Flywheel / clutch turns at 7K, starter housing turns at 0 RPM. Trim the starter/ bell / whatever. Leave the rotating mass alone!!!
            • Agree Agree x 1
            • Ron816
              230
              147
              Nov 15, 2019
              Quincy, MA
              Local Time:
              6:36 PM
              I j
              just pulled the clutch back out question is on the disk which side does the the hub goe flywheel or pressure plate?
            • toolmanmike
              toolmanmike FABO MODERATOR Staff Member FABO Gold Member
              52,767
              38275
              Jan 18, 2006
              Iowa
              Local Time:
              5:36 PM
              Pressure plate. Flat side to the flywheel.
              • Agree Agree x 2
              • inertia
                3,323
                585
                Feb 4, 2011
                Local Time:
                3:36 PM
                The disc won't go in backwards, the flywheel bolt heads will interfere .
                Borg and Beck or Diaphragm design pressure plate ?
                If B&Beck, install and measure height to the three fingers/levers , they should be very, very close .
              • Ron816
                230
                147
                Nov 15, 2019
                Quincy, MA
                Local Time:
                6:36 PM
                Borg and Beck
              • yellow rose
                yellow rose Master Of Insanity
                24,451
                20454
                Jun 19, 2015
                Walking a crooked mile
                Local Time:
                3:36 PM
                LOL, the disc WILL go in backwards. Seen it many times.
                • Agree Agree x 2
                • inertia
                  3,323
                  585
                  Feb 4, 2011
                  Local Time:
                  3:36 PM
                  Next time you get one - post a pic !
                  I'd really love to see it ! !
                  I knew I had you on "ignore" for good reason !
                  • Agree Agree x 1
                  • Disagree Disagree x 1
                  • memike
                    memike Super Moderator Staff Member FABO Gold Member
                    49,069
                    11818
                    Jan 8, 2006
                    on the hill
                    Local Time:
                    5:36 PM
                    I hammered a bell housing hard, cracked will let a clutch bounce
                    • Like Like x 1
                    • AJ/FormS
                      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                      19,185
                      7085
                      Jan 19, 2014
                      South-Central Manitoba,Canada, 900ftelevation
                      Local Time:
                      5:36 PM
                      Mopars don't get wheel hop, or so they say.
                      Is your wheel-hop maybe telegraphing into your left foot?
                      Have you checked the spring-packs for a broken element?
                    • rklein383
                      1,556
                      471
                      Dec 2, 2005
                      Local Time:
                      5:36 PM
                      Yep, been there, done that.
                    • yellow rose
                      24,451
                      20454
                      Jun 19, 2015
                      Local Time:
                      3:36 PM
                      Inertia says I’m stoopid because he says a disc can NOT be installed backwards.
                      Whatever.
                    • yellow rose
                      24,451
                      20454
                      Jun 19, 2015
                      Local Time:
                      3:36 PM
                      Yup, put me on ignore. I don’t have time for morons who say bullshit and get called on it and then still act the ass.
                      • Like Like x 1
                      • CRUZE 418
                        CRUZE 418 FABO Gold Member FABO Gold Member
                        274
                        89
                        Mar 11, 2019
                        Illinois
                        Local Time:
                        5:36 PM
                        Just asking, when you were installing the trans. did you stop to rest while the trans was partially in? You can damage the disc with the input shaft if you let the trans hang when partially in.
                        • Agree Agree x 2
                        • 67Dart273
                          44,981
                          12564
                          Oct 14, 2010
                          Idaho
                          Local Time:
                          3:36 PM
                          I nearly mentioned this, but indirectly I guess I did.......
                        • CRUZE 418
                          274
                          89
                          Mar 11, 2019
                          Illinois
                          Local Time:
                          5:36 PM
                          I mentioned this once before, do yourself a favor. Buy 2 long trans bolts say, 4 " or 5" , cut the heads off and screw them into the top two trans holes for guides when pushing the trans in. They just straighten things out. Easy install, and if you get tired, they will hold it while you recover.
                          Also, you did have a clutch alignment tool to center the disc?
                          • Like Like x 1
                          • RustyRatRod
                            RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                            64,404
                            37357
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            6:36 PM
                            He's right on this. When I replaced the clutch in my 64 Valiant after I first got it, I put the disc in backwards, because I was in the dark and wasn't paying attention. It will install backwards. I did it.
                          • RustyRatRod
                            64,404
                            37357
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            6:36 PM
                            Another thing that's a common cause of clutch chatter and shudder is grease or oil on the flywheel.
                            • Agree Agree x 3
