Stacked360
- Joined
- Mar 9, 2009
- Messages
- 195
- Reaction score
- 4
I've been told that the Police package Volare brakes will bolt up to disc brake A-Body spindles...has anyone else heard of doing this?
What is the difference between normal calipers and the police ones? Also, difference in rotors?
good deal, nice to knowThey fit 14s.
if someone is removing perfectly good, working brakes just because they got a bigger set, and they don't know what the trade off's are, that's not cool.What difference does it make about the need? If the brakes are there and available, use them. The A body stuff is gettin harder and harder to find every day. Since the F, M and J brakes interchange easily and work well, use um.
you don't "have to" change them. they may not feel exactly the same as they would with the matched parts, but that doesn't mean they won't work just fine. you might end up with higher or lower peddle effort and/or longer or shorter peddle stroke. that may or may not be a good thing, depends on the driver...but you'll have to change or swap the Master Cylinder as well as the proportioning valve.
Precisely,...But I had the car to part out, and I like a high hard pedal,...I did It cause I got tired of puttin rotors on the truck after towing my little Omni's and Horizon up and down the hills here.
