F Body Soild,Safe and Secure???
ZZZBrahmaBull
Active Member
Hallettsville Texas
Since a Dodge Aspen is a uni-body.It be absolutely crazy to not make the frame chassis as one solid unit to race it or even a street hot rod.Any one make frame connectors or gotta do custom fabrication modifications to do that?I can feel the Aspen sort of twist when i get into the gas around 80mph.
Safety is my biggest concern.Any advice???
frame connectors alone wont stop twisting but they will help. a roll cage will help even more. if you have cutting and welding skills just get a 2x3 square tube and cut and weld to fit. make sure it's on end and not flat.
Replace the factory rubber k-frame mounts with solid aluminum mounts. This ties the front frame rails together using the k-frame like an X brace.
