Fact-check me on sandblasting, would you?
Shop, Garage and Tools
  1. Bill Crowell
    Bill Crowell FABO Gold Member FABO Gold Member
    945
    489
    Oct 16, 2007
    Diamond Springs, CA
    Local Time:
    9:40 AM
    For sandblasting I use an old TIP pressure blaster fed by a 12-hp, 25 SCFM compressor. I have always been pretty happy with this setup because it will blast parts about as fast as you would want to blast them. I use regular sand for my abrasive media; I blast outdoors; and I do not re-use the sand. (Of course I am careful to use breathing protection.)
    Here's my question: First, I know you can't use a cabinet blaster to clean parts with layers of dirt and grease because you are re-using your abrasive media and the grease will contaminate it. But when you are not re-using your media, is there any reason not to blast dirty & greasy parts? Thanks for your opinion.
  2. doug 371
    doug 371 Well-Known Member
    2,059
    284
    May 29, 2004
    Regina, SK CANADA
    Local Time:
    4:40 PM
    I blast greasy parts too...never an issue...
    • Agree Agree x 2
    • toolmanmike
      toolmanmike FABO MODERATOR Staff Member FABO Gold Member
      52,967
      38458
      Jan 18, 2006
      Iowa
      Local Time:
      11:40 AM
      I always degrease parts before blasting.
      • Agree Agree x 7
      • Like Like x 1
      • Bill Crowell
        945
        489
        Oct 16, 2007
        Diamond Springs, CA
        Local Time:
        9:40 AM
        It would be very labor-intensive to degrease some of the parts I've got, Toolman.
        I guess what I am really asking is, when you sandblast greasy stuff, do you drive a lot of the grease into the metal so you get lots of fish eyes when you try to paint it?
      • doug 371
        2,059
        284
        May 29, 2004
        Regina, SK CANADA
        Local Time:
        4:40 PM
        I will degrease them too but that's just to get the heaviest stuff off...no fish eye problems Bill
        • Agree Agree x 1
        • toolmanmike
          52,967
          38458
          Jan 18, 2006
          Iowa
          Local Time:
          11:40 AM
          All the gunge gets mixed with the media and gets blasted onto the part.
          • Agree Agree x 1
          • Bill Crowell
            945
            489
            Oct 16, 2007
            Diamond Springs, CA
            Local Time:
            9:40 AM
            I think I will just soak the parts in naptha until I get the worst of the grease off, and then sandblast them. I just can't see any way of getting some of that baked-on dirt/grease off without blasting it.
          • toolmanmike
            52,967
            38458
            Jan 18, 2006
            Iowa
            Local Time:
            11:40 AM
            Before degreasing, after degreasing, after blasting.
            • Like Like x 3
            • halfafish
              halfafish Damn those rabbits, and their holes! FABO Gold Member
              1,801
              1585
              Aug 14, 2016
              SW Washington
              Local Time:
              9:40 AM
              For degreasing, try Easy-Off oven cleaner. I like the pump bottle stuff, as it's easier to direct the flow where I want it. The aerosol version tends to be real powerful and splashes all over, including on me. I leave it on for about 10 minutes then rinse and repeat as needed. It works very well and seldom needs more than one extra application.
              I agree with the others, for stuff going in the blaster it needs to be degreased before getting blasted. Outdoors with no recovery, it wouldn't make any difference.
              • Agree Agree x 2
              • YY1
                YY1 Well-Known Member
                7,033
                2729
                Oct 11, 2011
                FL
                Local Time:
                12:40 PM
                I scrape as much off as I can with a putty knife.
                Then if I can, a wire brush.
                After that it goes in the cabinet.
                I've not had an issue reusing/recycling play sand and I even scavenge what I can when I blast outside, over a blue tarp.
                Even at $3 a 50 pound bag, it goes quickly and adds up. I can usually reclaim between 25 and 40%.
                I do sift it before reuse (actually before the first use as well). It's tedious and time consuming, but necessary or you get blockages.
                • Like Like x 1
                • Agree Agree x 1
                • 4spdragtop
                  4spdragtop FABO Gold Member FABO Gold Member
                  29,610
                  9928
                  Aug 28, 2009
                  Wasting time here
                  Local Time:
                  11:40 AM
                  I reuse/soft mine as well. I strapped an old rubber bottomed elec sander onto side of 5 gallon pail. Holes in bottom of pail and media goes thru pail and into a strainer/sifter. Annoying listening to the sander tho lol.
                  • Like Like x 1
                  • Thanks! Thanks! x 1
                  • younggun2.0
                    younggun2.0 Well-Known Member
                    4,675
                    978
                    Jan 27, 2012
                    federal way, wa
                    Local Time:
                    9:40 AM
                    I take my parts to a local tranny shop. They run them thru the parts cleaner for a case of beer.
                    • Like Like x 3
                    • Dartnut
                      Dartnut Don't hate me because i'm beautiful
                      10,971
                      3382
                      Apr 19, 2007
                      Southern Alberta
                      Local Time:
                      10:40 AM
                      Now, that's a good deal if it's cheap beer!
                      Not that 2 bucks a can stuff..........
                      Lol
                      • Like Like x 1
                      • famous bob
                        famous bob mopar misfit
                        17,554
                        7035
                        Aug 14, 2011
                        okla
                        Local Time:
                        11:40 AM
                        Try some engine degreaser , I bought some by accident , (wasnt looking at what I picked up) , I did finally use it a couple of weeks ago on a 68 form S front end thats been laying untouched in an old trailer box , worked fantastic , just hosed it of --------------
                      • sireland67
                        sireland67 FABO Gold Member FABO Gold Member
                        9,296
                        3488
                        Oct 27, 2010
                        WV
                        Local Time:
                        12:40 PM
                        I soak my old greasy parts in cheap paint thinner from the hardware store, recycle it when done.
                        A cheap rubbermaid container from the dollar store, is my soak tank.
                        Let is soak for a few days and hit it with brake cleaner.
                        Sandblasting grease, is like hitting a spring, it just bounces off, or shoves it around.
                        • Agree Agree x 5
                        • Bill Crowell
                          945
                          489
                          Oct 16, 2007
                          Diamond Springs, CA
                          Local Time:
                          9:40 AM
                          I guess I'm going to find out, sireland67! Thanks for all the replies.
                        • 4spdragtop
                          29,610
                          9928
                          Aug 28, 2009
                          Wasting time here
                          Local Time:
                          11:40 AM
                          What I've found and read is media needs a firm surface to be effective. Any soft stuff like has been mentioned is ineffective.
                        • my68barracuda
                          my68barracuda Well-Known Member
                          1,396
                          1072
                          Dec 6, 2009
                          Indianapolis IN
                          Local Time:
                          12:40 PM
                          for greasy stuff,,, I take it to the local quarter car wash to blast off the heavy loose stuff, then use a solvent to work on the remaining greasy film, then blast.
                          • Like Like x 3
                          • YY1
                            7,033
                            2729
                            Oct 11, 2011
                            FL
                            Local Time:
                            12:40 PM
                            They will run you out if they catch you, and you'll be asked not to return, usually under threat of the law.
                            • Agree Agree x 2
                            • my68barracuda
                              1,396
                              1072
                              Dec 6, 2009
                              Indianapolis IN
                              Local Time:
                              12:40 PM
                              the quarter car wash that I use is attached to a full service car wash,, by law the water run off is collected and cleaned to what ever the law requires prior to discharge into the sewers. At most car washes at least a portion of the water used is recycled.
                              How Car Washes Work
                              If there was a mess on the walls / floor I take a little bit of time to rinse down the bay when finished,, never had a problem.
                              Perhaps the car wash bay that you used is discharging directly into a sewer or near by stream, in that case there would be a problem.
                              • Like Like x 2
                              • 69FBCuda
                                69FBCuda Life in the Fast Lane FABO Gold Member
                                2,767
                                1455
                                Aug 28, 2014
                                Florida
                                Local Time:
                                12:40 PM
                                Pressure washer does a good job, if you can run hot water it works even better.
                                • Agree Agree x 2
                                • Dartnut
                                  10,971
                                  3382
                                  Apr 19, 2007
                                  Southern Alberta
                                  Local Time:
                                  10:40 AM
                                  That's why you do it at 3 am when nobody's around...........lol
                                • 6PakBee
                                  6PakBee FABO Gold Member FABO Gold Member
                                  83
                                  37
                                  Feb 8, 2020
                                  North Dakota
                                  Local Time:
                                  11:40 AM
                                  • A56
                                    A56 MoParAffliction FABO Gold Member
                                    1,677
                                    1900
                                    Jun 24, 2014
                                    South of the Mason-Dixon Line
                                    Local Time:
                                    10:40 AM
                                    That's funny. I hooked my pressure washer up to the bottom of my hot water heater drain valve a few times.
                                    • Like Like x 2
                                    • SLOPAR72
                                      SLOPAR72 Well-Known Member
                                      2,225
                                      1614
                                      Jan 5, 2016
                                      Richmond, VA.
                                      Local Time:
                                      12:40 PM
                                      I have the same pressure blaster as you OP. She is a bad mother trucker lol... And I have 2 blasting cabinets. No, i'm not entitled, it just worked out this way lol...
                                      The cabinet can do what the pressure blaster does. No way, no how. And yes I always remove most grease and grime. I also reclaim and sift from time to time. One cabinet has oxide. The other has Black Beauty.
                                      As for paint surface compromise, I have never seen that problem. As said easy off, a trip to a car wash, whatever you do to remove the crap so it won't muck up your cabinet is an evil reality to having a Cabinet lol...
                                      JW
                                      • Like Like x 1
                                      • Agree Agree x 1
