Factory console tach wiring
taflick68
Member
Hi all
Hoping that someone as some info for me
I'm trying to find the factory correct way to wire a console tach on a 68 dart 4 speed. Where the coil lead wire goes, if all the way to the coil where does it go through firewall, pictures would be great. where the ground wire is attached and where light and power wires attach. I'm hoping to be able to do this and make it as correct as possible
Thanks a lot in advance if anyone can help
Should be the same as a 69:
[ame]http://www.abodyjoe.com/pictures/Misc.%20car%20info/69%20dodge%20service%20manual.pdf[/ame]
Page 8-99 is specific to the console
Engine bay is 8-101 Find T11-18GY/T coming off coil neg. This goes through a separate grommet in the firewall
Now what's BETWEEN is not really shown, LOL
You can get some idea by looking at the Cornet wiring page 8-105 / -104
The 70 manual is just as bad:
[ame]http://www.abodyjoe.com/pictures/Misc.%20car%20info/70%20Dart%20Challenger%20Serv%20Man1.pdf[/ame]
Page 8-89 is the engine bay, this time they actually depict the firewall grommet but little else for the A body, and 67 doesn't show where the rest goes in the instrument panel either.
Basically you have ground, lamp, trigger and switched ignition power
Black, ground
orange, lamp
violet or dark blue, power
dark green trigger
http://www.abodyjoe.com/pictures/Misc. car info/69 dodge service manual.pdf
http://www.abodyjoe.com/pictures/Misc. car info/70 Dart Challenger Serv Man1.pdf
Black, ground
orange, lamp
dark green trigger
That's perfect thank you so much
