[SOLD] Factory (edelbrock) alum intake
340 demon 72
Wisconsin
I've got a very nice edelbrock aluminum intake with a Chrysler part #on it. LD4B is the casting number on it. No stripped threads , could use cleaning up tho. Looking to get 300.00 or best offer for it and the carburetor. Plus shipping and 4% paypal Located in Kenosha Wisconsin.
the carb is not broken not sure where you see that it looks broke the carb will need to be rebuilt im sure
Look near the back of the carb, there is a piece that sticks up approx 1" only on the pass side. I believe there should be one beside it on the drivers side as well.
What is the carb?
Thanks Dar, I noticed the fuel inlet was different. Not sure which one of the car mfg it was for??
Steve...its definitely not Mopar....check the fuel inlet location.....
sorry about that had the wrong carb on the intake but what you are referring too is the way it was cast
could have came on a mopar also heres a pic of an original 273 with carb View attachment 1714985059
Your original carb picture is nothing like the 273 AFB you have pictured in post #16....check out the fuel inlet to start with...there are many other differences too. As has been stated, it's from an Oldsmobile. Yes, they are both Carter AFB carbs, but totally different application for each one.
