Factory seam sealer??
Mopar Body and Trim
  1. Roadart
    Roadart Well-Known Member
    225
    46
    Jun 18, 2018
    Escalon ca.
    Local Time:
    9:34 PM
    What did the factory use for seam sealing? on a 72 dart. Was sanding roof to epoxy seal for paint,when i got to the side near 1/4 panel a lot of body filler appeared. Dug it all out and found the seam(top to 1/4 panel) Guessing p/o filled it in .
  2. Alaskan_TA
    Alaskan_TA Well-Known Member
    5,751
    4064
    Nov 12, 2004
    PA
    Local Time:
    12:34 AM
    Body filler and / or lead was normally used at the C pillar roof seam.
    Seam sealer for internal areas, trunk floor, firewall, floor boards, etc.
    • Agree Agree x 1
    • crewchief
      crewchief A & P Mechanic FABO Gold Member
      498
      229
      Jan 17, 2014
      Malta NY
      Local Time:
      12:34 AM
      Exterior panels attach areas should have been leaded. As Alaskan said internals is where seam sealer was used.
    • MoparMike1974
      MoparMike1974 FABO Gold Member FABO Gold Member
      2,768
      2014
      Jun 16, 2017
      Maryland
      Local Time:
      12:34 AM
      The quarter panel seam was leaded up until around 71 then they switched to body filler. The leaded ones do not have the rot problem the later ones do. For the other seam sealer in the car they used at least three different types. There was the "foamy" type used around the cowl seams and under the top edge of the fender. They had one type that was similar to what is typically available now. Third was a thick rubber/tar type used a lot in the trunk area and floor pans.
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla
      66,098
      39500
      Jun 7, 2010
      Georgia
      Local Time:
      12:34 AM
      Nope. That was very likely factory body filler. They all had it there.
    • MoparMike1974
      2,768
      2014
      Jun 16, 2017
      Maryland
      Local Time:
      12:34 AM
      When you replace it use a waterproof filler like metal-2-metal or kitty hair. Regular body filler absorbs moisture, just like the stuff the factory used.
      • Agree Agree x 1
      • Kendog 170
        Kendog 170 Let the boy go !
        1,460
        942
        Mar 10, 2016
        Tewksbury Ma.
        Local Time:
        12:34 AM
      • Kendog 170
        1,460
        942
        Mar 10, 2016
        Tewksbury Ma.
        Local Time:
        12:34 AM
        Oh you only need a quart. A little goes a long way.
      • Danco
        Danco FABO Gold Member FABO Gold Member
        106
        8
        Apr 2, 2015
        Maine
        Local Time:
        12:34 AM
        I just replaced my factory roof skin on my 74 duster and it was lead filled at c and a pillar along with lead at taillight panel ends
        • Like Like x 1
        • JDMopar
          JDMopar Well-Known Member
          3,460
          2353
          Jan 19, 2012
          Candler, NC/Myrtle Beach, SC
          Local Time:
          12:34 AM
          The factory used lead for cars with painted tops, and body filler for vinyl top cars. The best thing to do when you rework it, is to sandblast the seam where the top and quarter meet, and then coat it with GOOD epoxy primer like PPG DP90 or SPI epoxy primer. Then use the Tiger Hair or 3M stuff listed above to smooth the seam. A good base coat of either one of those 2 is fine, and then do your finish work with good body filler like Evercoat Rage Gold.
          • Agree Agree x 2
          • Like Like x 1
          • Roadart
            225
            46
            Jun 18, 2018
            Escalon ca.
            Local Time:
            9:34 PM
            Thanks to all, had a feeling body filler might have been factory. Will fill with the right stuff thanks .
          • crewchief
            498
            229
            Jan 17, 2014
            Malta NY
            Local Time:
            12:34 AM
            I'm "old school", I prefer lead whenever and wherever possible. Many autobody suppliers still sell it. I find using lead solder paddles to be relaxing.
            • Like Like x 1
            • forphorty
              forphorty Well-Known Member
              705
              287
              Jan 19, 2006
              Local Time:
              11:34 PM
            • MopeGarage
              MopeGarage New Member
              1
              0
              Nov 10, 2020
              Vancouver WA
              Local Time:
              9:34 PM
              Somthing i want to learn!!! Think ill have the chance on the 69 Dart I just dragged home!!
            • crewchief
              498
              229
              Jan 17, 2014
              Malta NY
              Local Time:
              12:34 AM
              You will find that leading is so easy once you master the technique. The finished product is rewarding. There are many videos out there, Eastwood has a blog on the subject.
              • Like Like x 1
              • 67Dart273
                67Dart273 FABO Gold Member FABO Gold Member
                45,856
                13592
                Oct 14, 2010
                Idaho
                Local Time:
                9:34 PM
                I hope, before I die, I get to kill the guy who thought vinyl tops "were a good idea"
              • crewchief
                498
                229
                Jan 17, 2014
                Malta NY
                Local Time:
                12:34 AM
                Mine looks like the day it was installed. I used Ralley Vinyl Top Dressing since it was new, treated once a year until I ran out of the stuff. I believe that what saved it and no rust bubbles to be found. I wish I had purchased several spare cans.
              • A56
                A56 MoParAffliction FABO Gold Member
                2,054
                2705
                Jun 24, 2014
                South of the Mason-Dixon Line
                Local Time:
                11:34 PM
                It might have been a woman's idea to "decorate" the roof.
              • crewchief
                498
                229
                Jan 17, 2014
                Malta NY
                Local Time:
                12:34 AM
                You have to blame the "Naugahyde" popularity in the 60's & 70's. Designers went crazy with the product and apparently Detroit picked up on it!
                Too bad there became a shortage of an animal called a "Nauga." The rest is history.
