Fan blade
CRUZE 418
Illinois
I only have a '69 parts manual, this fan blade number isn't there. #3462 186, it has aluminum blades. My friend says it's for a 426 Hemi. The blade in my '69 parts book says # 2863 215. Can someone help me out? I will use it regardless, it fits. Just trying to settle the argument.
#3462186 is for 1974 B and C body with 318 360,400, and 440 7 blade with A/C 20" diameter.
The #215 blade fits a lot of applications between 68 and 72 small and big block and Hemi.
That sounds right. This fan is 19" in diameter. I figured the higher part number would lead to a later model. Will see when I get the Hemi car back on the ground.
Thank you!
Fan
