fxrtharley
Member
Hi all, I am looking to add a fan shroud but nowhere am I able to see how the shroud is secured to the radiator. I have what I believe to be an aftermarket radiator but there are four holes near the same location as shown on what I also believe to be the correct shroud from Mancini. I find the clips as shown to be the ones for this model but I don't know how they attach to the radiator. The four holes in the radiator frame are tight against the core so there is no room for the threaded side to go in between frame and core. Does anyone have a picture or know how I can mount the shroud? I have a 68 barracuda with a small block and 20 inch fan
Thanks
Thanks
