Fan shroud
I'm looking for a fan shroud for my 72 Dart with 318 and a/c. The part number is 2998325. It's for a 22" radiator.
Thanks
I'm pretty sure i have one, I need one for a 69 and bought this one to find out it was for a newer car. I can check tomorrow when I get off work. Thanks
I bought the wrong shroud twice at swap meets and lost money on the resale twice. LOL
FInally did get a correct OEM complete with undercoating overspray a a decent price.
Having a part number reference or atleast a tape measure at swap meets...
PRICELESS
Seriously , take nothing for granted. Go by the bolt hole measurements radiater to shroud.
Good luck
PRICELESS
Good luck
I know what you mean, I thought I had remembered the part number I needed when i bought this one. WRONG!!
I just went and checked. The one I have is 3673821. I'm not sure what it fits. Does anyone know? The one I need is 2785614, if you can help.
Yup that one is a little high, If anyone has a 2785614, Let me know. I'm getting close to needing one. And maybe someone can verify this part number. I need one for a 69 Dart V/8 with A/C. Thanks in advance.
thanks for the replies, I appreciate it. I'd rather buy from a member but still watching ebay.
Scott
The numbers are correct for the respective year models yall seek but...
I'll repeat myself, "Question the shroud bolt spacing !" Also confirm your car still has the original radiater. 3 different 22 inch radiaters all take a different shroud.
Since you seem to be the one with the knowledge on these things, I checked the part number on the radiator 2949069 does this match the shroud I'm looking for? 21 7/8" across and 13 1/2" up and down. I didn't mean to hyjack this thread. Sorry
There is two other ones on ebay right now, both 22", both were at 20 some bucks when I looked at the about an hour ago.2:30 left coast time.
Yep Thats the same radiater # I have. 3 of , but only 1 shroud.
Its not the best of 22 Inch radiaters even for that year.
4 core BB radiater was ####089? my memory sux.
That number used same ### 614 shroud.
Beware repop shrouds too. Some poor material / quality repops out there . Plastic that warps with heat and fiberglass that could be already warped when it arrives :(
Good rule of thumb for shrouds is "If it shines, it's crap"
Seems everything on ebay has an average price with a wide range. That 614 shroud can bring 179.00 or 92.00. Everyone gets lucky once in a while.
I uesd regular ebay and [22 shroud] for general seach term and looked through a lot of stuff before I got lucky. Hope this helps
Thanks for your knowledge, I guess i'll keep looking.
