Fastback trunk divider replacement.
bacaruda
WV
Is there anything you could use instead of wood? Maybe some
composite, 'styrene, laminate, lighter.
Jim.
what ever you use to make it with it has to be about 1/2 inch thick to fit the trim properly. I used plywood but I thot about using some counter top from the local hardware stores bent and dent aisle (cheap)
AdamR said:
Thats the sound deadner for a coupe.
Oops... My bad! We're back to that "posting without my morning coffee" issue again...:sad3:
Well on weekends I don't get on here as much as I want to. Too much to do.
But missed the EBAY, and Adam, the first idea is good I like aluminum.
But I want it to be close to stock, not wood, and aluminum would reverb
like hell.
Thanks, more?
Jim.
