The little things that don't show seems to take a lot of work.No more pictures but lots of work done! E-brake system on, trans shifter on, t-case shifter on, steering box, pitman arm and drag link on. And a whole bunch of other little stuff. Primed the oil pump and it hit 75 psi off the drill motor. Getting ready to run the motor, ignition is almost jibbed up, going to take the carb off my Duster just to make a test run. I still have to clean up the headers and get them on too!
Cley
Good job and am sure is done right.
Cab will be on soon I bet.
