Fatman spindles
Darter6
Nevada
Has anyone used or know of any trouble with Fatman Fabrications spindles?
I have a set of the 2" drop spindles that I installed with tubular upper arms ( non adjustable ) and cannot get the camber setting less than a + 2 degrees with the cams set as far neg - as they will go. All front end parts are new and the car ran and drove straight ( no wore out parts ) before. The car is a 63 Valiant.
I run Fatman spindles and adjustable tubular uppers. In any case, I would look to the control arms for your problem - not the spindles.
