Fel Pro rear seal ?
68383GTS
East Peoria,IL
I don't ever remember using these parts with a 383 rear seal kit. What are these used for?
Do you guys use rtv in the groves of the retainer plate on the side seals?
I use them.
I rtv them too.
Used to be composite like side wedges you would rtv up and slide in the side as you I stalled the seal cap
Those top in the pic, theyre locators , right?
Keeps the seal lips lined up so it doesn't leak
I don't think I have ever used the parts in the picture. So these parts are not suppose to be installed? Fel Pro instructions are poor. I am replacing it while the engine is in the car.So much easier with the engine out ...lol
Yes, the walls on the rear seals and corners should get a thin coat of RTV. 65'
The mystery pieces included in your rear main seal package are in there because that seal kit not only fits a big block but also fits a slant six! That's where the extra parts get used.
