[WANTED] Fender Mounted Turn Signals
Probably 1 wire. I believe the 2 wire ones started in 73 and have a visible mounting screw through the top of the bezel.
I have this one, need to be restored.
68-69 barracuda all were hood mounted. The barrel connectors for them come out of the wiring harness at the center point of the firewall. Wires run inside the inner hood web structure. Drill template I used was from a 69 barracuda hood. If you see em on the fender of a 67-69 cuda, somebody added them, and in the wrong spot. 67s these werent available. 69 they were part of the A01 light package. Since we used a 74 dart hood, I had to drill for them.
I've seen theirs on eBay. So you opted for the hood mounted version? :)
I was thinking about finding a decent used set. Sanding them down, and painting them body color...
Fender Mounted Turn Signal Lights 73-76 Dodge Charger Dart Satellite A B E Body | eBay
Those are actually 73-77, but they have the mount screw thru the top. The ones with the mounting stud underneath are correct for 69-72. The ones from 521 are fender mount only in such that the power wire is too short for a hood mount. Black hook up wire, solder, and shrink tubing along with the splice being inside the hood web to hide it, makes it just fine for a hood mount setup.
