Ive have tried to use the various applications to decode my 76 Duster's fender tag. Seems they only work on 75 and older cars. I have picked out some of the codes like the color but most I dont know. Can anyone here help?
![securedownload.jpg](http://i76.photobucket.com/albums/j12/jcmini30/My%20Duster%20RestoMod/securedownload.jpg)
you can give it one more run with this one too.. www.stockmopar.com
yep, you are correct, i just tried it myself, crap, my bad, i havent used them in a while. they are probably going to start charging people ....When I enter the VIN I get an error that says they have discontinued the service...
Thanks guys, AdamR's link did most of it, pieced with other comments are as follow:
VL29:
Plymouth Valiant,Duster
Low
2 Door Sports Hardtop
G6G: 383 325HP 1-4BBL 8 CYL
1966
St. Louis, MO, USA
^ Not sure this is right, Should be 318 and 1976... Plant code may still be right.
205361: Sequence number
E44: 318 cid 2 barrel V8 230hp
D32: Heavy Duty Automatic Transmission
KG8: Exterior Color-Sherwood Green Metallic
E2F6: Trim - Unknown, Vinyl Bench Seat, Green
000: Full Door Panels
428: Build Date: April 28
T76714: Order number
V1W: Full Vinyl Top, White
U: USA Specifications
B41: Front Disc Brakes w/Standard 10in RR Drum
G52: Remote driver side mirror
H51: Air Conditioning with Heater
M21: Roof drip rail moldings
N21: Air pump
N37: Catalytic Converter
N95: Emissions Control
R11: Radio Solid State AM (2 Watts)
K5X: Body side molding protective vinyl insert black (?)
26: 26in Radiator
A3: Unknown
END: End of Sales Codes
This is great cause it tells me my car was basically untouched when I got it. Only diff i can see is the body side molding...
