Fender Tag Help 67 Cuda
craig984
Active Member
Mesa Arizona
When I got my Cuda in 1982 it was a stripped shell with no drivetrain. I built the car with the help of parts cars for interior and drivetrain. I would like to know what my car was supposed to be, color, stripe, options ect. I have tried to decode this, but the early fender tags are a little tougher. Thanks for any help. Craig
this is what came up for me......
CAR: Plymouth Barracuda 2 Door Sports Hardtop
ENGINE: 273cid 4-bbl HP V8
TRANSMISSION: 3-Speed Automatic
TIRES: Unknown tire code
BUILD DATE: October 21.
AXLE: 3.23 Rear Axle Ratio, Sure Grip
INTERIOR: High Trim Grade, Vinyl Bucket Seats. Red Interior.
PAINT: Bright Blue Metallic w/ GTX Racing Stripe
OTHER: Bright Blue Metallic Upper Door Frame Color. Bright Blue Metallic Racing Stripe.
MOLDINGS:
ABC OPTIONS:
F7: Barracuda Formula S Package
R1: AM Radio
T7: Tachometer
abc OPTIONS:
j4: Moulding - Boldy Sill Narrow
k7: Passenger Outside Manual Mirror
I decoded your fender tag.It,s a nice car.CAR: Plymouth Barracuda 2 Door Sports Hardtop
TIRES: D70x14 Red Sidewall, nylon belted
PAINT: Dark Red Metallic w/ Racing Stripe
OTHER:
MOLDINGS:
ABC OPTIONS:
R1: AM Radio
T7: Tachometer
abc OPTIONS:
a6: Console
b4: Bucket Seats
j4: Moulding - Body Sill Narrow
Thanks dartcuda, my problem is the cars floorpans trunk underhood and when I pulled the windows out in 82 to do my first restoration it looks like the cars original color was silver with a dark red stripe down the middle. also there was still trim on the top of the a pillar and the c pillar from a vinyl top. The build sheet was long gone with the interior. The number 17 that is stamped into the fender tag on the very right side is odd looking too, I am not sure what that stands for??? I have never seen another 67 with the center stripe and a vinyl top. Thanks for any help, Craig
thats not 17,look careful. the number 1 is under tha letter R,that means AM radio.The number 7 is under the letter T,thats means the car has a tach.
I think he is talking about what looks like a 17 on the far right of the tag (around the Z)
Even if that is a 17 on the far right is has nothing to do with options…. It is probably an inspection stamp the got accidentally on the tag in the process line….
I ran it again using that decoder…
Looks like the car was silver with a red stripe and red interior.
Car line........................................PLYMOUTH Barracuda
Price class....................................High
Body type.....................................2 door sports hardtop
Production date.............................October 21, 1966
Shipping order...............................25816
Engine.........................................273 4bbl 8cyl 235hp LA [373/382]
Transmission.................................Torqueflite automatic
Tires...........................................14 red 2-4 nylon-special (x5) [432/448]
Axle............................................Axle-3.23:1 [404]
Sure grip......................................Axle-sure grip [408]
Trim Grade....................................High [32H]
Seat type.....................................Bucket vinyl [336]
Trim color.....................................Red [34R]
Paint 1........................................ Dark red metallic [27Q]
Paint 2.........................................Silver metallic [28A]
Upper door frame paint....................Dark red
Buffed paint..................................Special buffed paint [708]
Radio...........................................Radio-AM Music Master/economy 2 W
Gauges........................................Tachometer [577]
Bucket seat accessories..................Console [486]
Front bucket seats.........................Bucket seats [564]
Mouldings......................................Moulding-body sill-narrow [544]
Mirrors..........................................Mirror-outside RH manual [537]
