no the bezel screw location or angle is different think the headlights in a slightly different spot also cant quite remember...u can change the headlight mounting panel tho or mod existing to make them work...welding required
Thanks, I remember that happened when we installed 73 Dart fenders on a 67 Dart.Head lights were in the wrong spot when installing the bezel.
Now if I go with a 70-72 Grille,filler panel,and hood along with fenders all would be good ?
