---Doing something different with my 64 Dart, gotta 636 ive just stated setting up doing semi fender wells, 2 inner pipes through inner fenders and other 2 inside, also did a few other mods to rails so it will have tire clearance and wont have to sit up like a 4WD
---Yea, the motor & trans mounts themselves keep the engine where it should be.
NOT using the stock engine & trans mounts normally requires a motor plate &/or mid plate with a fabricated trans mount.
That is a huge diameter tire for that car. (27)---
Ok. I was curious about this as I've started a 68 Dart build, RB block and will be using an engine plate. Want to run at least a 26 to 27" front tire. Want to go with fenderwell headers and wondering what would need to be modified to get the motor back enough. I haven't purchased headers yet.
would need A LOT of work on the firewall to push motor back, limiting factor in my car is the head oil drains, saying that can't see how pushing it back will give anymore tire clearance. check the photo, this is a Aussie Hemi 6 ive fitted into Aussie Holden Torana.......iv'e pushed the motor back 8 inches---
Just wondering - is it possible to do some mods to the firewall in order to get the motor back enough to run a 26" tire? Might not be possible, not sure what is keeping the motor from going back an inch or 2.
Pipes are done!!
Yep slip joints, still painful to fit/remove, drivers side is super busy and yep wanted a big big block in my street car.....finally got onea 10-plus on visual. I would guess you have slip tubes to remove / install.
they say ....go big or go home....you went BIG (cubes).....nice!!!
---Yep slip joints, still painful to fit/remove, drivers side is super busy and yep wanted a big big block in my street car.....finally got one
---I used the 15" tire called for on VW beetles back in the '70's with a narrow Centerline wheel (fenderweill headers were Cyclone). Can't remember the offset or rim size. Did not have any clearance problems.
