So a question a likely already know the answer to. Just got to the point in my rebuild of the original 67 A904 from the Barracuda. I failed to check my end play before disassembly. Checking it now after reassembly I have 0.110". Service manual says specs are between 0.022" and 0.091". I measured the fiber thrust washer between the input and output shafts while apart at 0.065". The kit I bought for rebuild did not come with a new thrust washer. Transmissionpartsusa.com has available a 0.068" and 0.083". I just need someone else to tell me for sure I'm a DA and have to pull the front gear train again for a $1.34 part to get it into spec and not tear up a fresh rebuild. SMH...
