My '72 Valiant needs help in the weight-distribution department.
I have been considering a lightweight (race-type) flat, stock-appearing fiberglass hood and front bumper for it.
Here's my question; laugh if you want to, but I am dead serious and will welcome any replies... pejorative, ridiculing, demeaning, or otherwise...rofilel:
I want a pin-down hood that will be held in place by four "hood pins," and that's conventional, as far as I know (I'll remove the stock hinges.)
What is NOT "conventional," is, I want to cut that fiberglass hood into two pieces, laterally. That would mean slicing it straight across, about a foot ahead of its back edge.
Here's the scenario....
I want to place the rear hood pins about 14-inches forward of the back edge of the hood, and slice a 1-foot long, full-width, straight section off the back of that hood, and re-attach it with a "piano hinge," one of those long, simple, barn-door-like hinges that will allow the piece I sliced off, to lie flat in its original location UNTIL pressure from in the engine compartment builds up and forces the rear portion of the sliced-off section of the hood, to rise up (pivoting on the piano hinge) and let the air out, as I speed down the track. When I slow back down, gravity (and maybe a spring) will return the back side of that "flap" to its original location, flat against the inner fender panel hood-support "ridge."
If this will work, it should accomplish several things:
1. It will release trapped air that came through the radiator, assisted by the fan.
2. It will deposit air into the airstream at the base of the windshield, and the profile of this "flap", sticking up, will act as a "spoiler," disturbing the normally high-pressure air are at the base of the windshield. Whether this will help move that air over the top of the windshield is debatable; it could hurt more than it helps; we'll see.
3. The structural strength of the hood may be increased by the attached hinge, which will go all the way across the hood, with no break in the attachment configuration. Should make the hood more solid, hopefully.
4. May slightly lower underhood engine temperatures due to increased air-flow though the engine compartment.
Have I lost my mind, or could this actually work as planned???????
Any and all comments welcomed. I need to know whether this is Alzheimer's related; God knows I'm old enough....
Just tryin' to get that ol' Valiant into the good 11's...
Let me know what you think! Please.........:read2:
