Figured out leak
7dart0
peabody,ma
Finally figured out my pan isn't leaking. Its leaking from the neutral safety switch, but through the pins on the switch not the gasket. It's a newer switch and works fine.
Is there anything I can do?
Thanks
I don't recommend this but you could clean the oil out of it, put some rtv in the plug and put the mating connector in. Allow to setup for 24 hours.
Again I don't recommend this for MANY reasons
Replacement is the best answer
I haven't found a non-leaking new switch in decades,always thru the pins.
My solution is a thorough thorough cleaning involving lots of compressed air, brakleener and depressing the ball while blowing from through the pins. Then I crazyglu the pins and invert the switch to let it dry. After that I hit it with the Seal-All.
