Filling in Ports to make more power!?!
Cleveland, Boss, Tunnel ports are known to oversized for most applications.
If you want more power and not spend a fortune, install a nitrous oxide set up, No cylinder head or intake manifold work required.
Kind of, there's only so much nitrous you can put in a stock engine, and has limited use.
For NA power you got low hanging easier to get then there's the harder more expensive usually smaller gains per mod, unless your in a highly competitive race class especially with a lot of rules most go for easier but usually less efficient power.
Not everyone wants to hit the “easy” button. Some of us like to actually work at building horsepower and earning some pride.
