Finely broke a 10 second pass
19DART66
Ballston Lake NY
Went to Lebanon Valley on saturday(oct 2) first pass of the day was a 11.021 at 123.84 with a 1.635 60 ft spun the tires real bad. Second pass bioled the sicks and pulled a 1.549 60ft, tires spun about 3 revolutions then hooked, then I missed 4th gear ( I shift into 4th before the 1/8) but the car still went a 7.000 1/8 and 11.156 at 120.52. Third pass same thing spun about 3 turns hooked to a 1.593 missed 4th again, this time I had to let completly out of it to get it to go in. Car went a 6.992 1/8 and 11.333 at 117.21( raised my shift pionts from 6400 to 6800) tried to get it in to 4th on the way back to the pits did not like going in, must have burd up the clutching teeth in 4th, trans is slick shifted. After seeing a 7 flat and a 6.99 1/8th I knew there was a 10 tobe sad so I lined it up one more time, the car spun again off the line and granny shifted 4th it went in with a loud grinding protest and rewarded me with a 1.565 60ft 6.996 1/8th and a 10.996 at 123.65.
WooHoo,I,m right behind you with a 11.01@121mph 60 ft is 1.54 1/8 is 6.95.I,ll be there soon.Congrats.:cheers:
