R RAVano Well-Known Member Joined Mar 27, 2018 Messages 311 Reaction score 336 Location Ct Feb 13, 2019 #1 Is there any benefit on putting a layer of Dynamat, Fatmat, etc on the firewall before installing a new firewall insulation and AC/heater box? Last edited: Feb 13, 2019
Mike69cuda Mopar Moron FABO Gold Member Joined Jan 2, 2018 Messages 3,549 Reaction score 3,342 Location Kansas City Feb 13, 2019 #2 That is what I did on mine. I think it helps isolate the engine noise and heat. Mine is an a/c car and the factory insulation is kind of sparse.
1969383S Proud Conservative FABO Gold Member Joined Jan 8, 2012 Messages 7,160 Reaction score 4,378 Location North Georgia Feb 13, 2019 #3 RAVano said: Is there any benefit on putting a layer of Dynamat, Fatmat, etc on the firewall before installing a new firewall insulation and heater box? Click to expand... Unless your going for a points resto it totally makes sense. Thin would be good so if using the factory insulation as well there will be no real fit issues.
R RAVano Well-Known Member Joined Mar 27, 2018 Messages 311 Reaction score 336 Location Ct Feb 14, 2019 #4 Thanks for the insight I'll add a layer before the install.
