challenger57
cuda57
I finally got my in. lb. gauge and redid my rear. I made an adjustable depth gauge and bolted a plate across the carrier bearing mount holes. I got it to the exact measurement it called for 2.770 and got my rotating pinion to 25 in lb prior to install of the carrier. It called for a .006 backlash but the the wear pattern indicated I needed to reduce the backlash. The pic shown is with .002 backlash and a pic of the adjustable depth gauge I made. What do you think and is it ready for install.
