[SOLD] FiTech 600 hp Power Adder Kit New/Used
mario03srt
Hillsboro Oh 45133
All,
I have a complete FiTech 600 hp fuel injection Kit. With New and used components/harnesses. This is a low use setup with a couple 1000 miles on it ran on my LA 360.
- This is a 600hp very low mileage Throttle Body setup that has been flashed with the Power Adder software. The TB has a new Bosch fuel reg and a new GM TPS. These are up grades from the chinese pieces. This will run a NA, Nitrous or centrifugal supercharger setup. Not Roots capable. This TB will also run on e85. Also has timing control for na/boost/NOS. Comes with a new hand controller thats matched to the PA tb. A 1" TB spacer is included for possible install mani clearance.
- Most of the rest of the kit is new and unused. New harnesses and fittings, o2 sensor install assy, etc. Included is a weather pack relay.
- Comes with a Fuel Command Center (fuel sump w/ 340 lph pump) with fittings. The FCC has been modified to have a return line that I dumped into the filler neck. The removed float assy is included. This is a common mod. Fittings, Bracket, and a 10 micron filter are included. (The stock mech pump feeds the sump and the 340 lph pumps grabs it and pressurizes it to 58 psi.)
If you are a small block guy, I will throw in a mech fuel pump and HEI Dist thats recurved and has a upgraded Vac can (Corvette SB) for free.
I'm still running a new FiTech setup and this setup has performed w/o issue.
$750.00 plus shipping. Prefer PayPal. But cash is king! Any question please let me know. This is a vg deal imo.
Marion Hutzel Hillsboro Ohio 45133
Hey Mario, is the fuel pressure boost/vacuum referenced/modulated, or is the fuel compensation strictly programming & duty cycle? Thx.
Jim K6
