Flaming River steering coupler
barracu67
Member
Tampa Bay
I have a question about the power to manual steering coupler from Flaming River. How does it connect to the column? Does it have slots in the end for the two pins in the end of the column & slip over them. I couldn't find any pictures of the column end of the coupler
Been a while since I installed mine but I know it attaches with a single roll pin.The other pin that is the axle for the stock coupler is not used . Probably should be welded on. If your gonna go his route you might save yourself some dough and get one from borgeson.but it's a bit more legwork to find the right one . I will say the thing I do like about the F/R unit is it's Stainless mine is about six years Old and still looks brand new.JM
If I remember right you drill a hole through the shaft and put a roll pin through the 2 pieces.
Some Flaming River coupler reference pictures.
I can take more if you need them.
Hope it helps.
Some Flaming River steering box reference pictures.
Here's a pic of the F/R Power to manual U-joint I used a bit different from the ones above
