PocketAces
The floor of my 65 convertible had rust in the back seat area. From the bottom everything looked pretty good, with lots of engine oil and tranny fluid to keep the metal protected from the elements.
But when I pulled the carpet, the inside was not so nice. The front foot wells were solid with surface rust only. The rear foot wells were very thin and rusted through in places. It was worse on the right, but there were pin holes on the left as well.
Also the center section was badly deformed, probably from a previous owners installation of non-original seats. You can see the extra holes that were drilled. They also did some beating with a BFH. This altered the height of the stock holes so the stock seats were not level.
