LEFT SIDE HEADER INSTALLATION: INSTALL FROM BELOW.
A. Remove the left engine mount bolt and raise the engine approximately three inches
(3"). Be sure to place a board between the oil pan and floor jack to prevent damage
to oil pan. Also, be sure to check the clearance of the fan to the fan shroud. Loosen
the shroud, if necessary.
B. Place the header into position.
C. Place the gasket into position. Install the front and rear header bolts. Do not tighten.
INSTALLATION NOTE: We recommend the use of a sealant on the bolts used to replace
the studs. This prevents coolant leakage.
D. Hold the header into position to avoid binding, while the engine is being lowered back
into position.
E. Reinstall the engine mount bolt. Torque to specifications.
F. Install the starter while headers are still loose.
G. Install the balance of the bolts. Tighten all header bolts progressively and evenly until
they are tight.
H.
Reinstall the clutch linkage, if so equipped.
I. If equipped with an automatic transmission, it may be necessary to raise the gear
shift linkage cross shaft by rotating the mounting brackets 180° on the frame and
transmission. See illustrations A and B.
4. RIGHT SIDE HEADER INSTALLATION: INSTALL FROM BELOW.
to the oil pan. Also, be sure to check the clearance of the fan to the fan shroud.
Loosen the shroud if necessary.
INSTALLATION NOTE: We recommend the use of sealant on the bolts used to replace
the studs to prevent coolant leakage.
D. Hold the header into position to avoid binding, while the engine is being lowered into
position.
F. Reinstall the steering linkage. Check for clearance between tube R-2 and the idler
arm. There must be a minimum of at least ¼. If not, replace the engine mounts.
G. Replace the spark plugs, oil filter, and coolant in the radiator.
Anyone know if these headers will work with a 4 speed setup? are they any good? how the heck do they fit so many cars also?
Flowtech Headers 33100FLT
http://www.summitracing.com/parts/BIG-33100FLT/
