Fluid Capacity Question
roosduster
Colorado Mopar
Littleton, Colorado
What is the fluid capacity for a A904 transmission? Also has anyone ever used B&M Trick Shift or Hurst Hot Shift Transmission fluid and have an opinion on them?
Thanks
Can't help about the fluid capacity, but use Type F (ford) fluid in your trans. The B&M suff is almost the exact stuff and about 10 times as much money. Chrysler has recommended the type F fluid since forever.
Haynes says it varies slightly but 4 Qts if your just draining the pan and changing the filter and 8 Qts if you are filling it from dry.
Chiltons said 16 pints. Hope this helps.
