send as pdf, it will retain original dimensions if your scanning it.E-mail-text wont work for a blueprint. Maybe someone near you has a fax.
Try to send, might get it on a flash drive then to my other printer, 5407752059Is your crank drilled deep enough for the input shaft of the manual trans? Is your crank reamed to accept a pilot bushing? Do you have access to a 31/32" drill bit? If not a 1.00" will work. Do you have a fax# the "blueprints" can be sent to?
