694spd
Can anyone tell me if this flywheel looks like a neutral balance one or one for an external balance motor?
Is it a 143T wheel? Looks like the ones that I've pulled from 400 4-spd 72-78 Trucks.
Interesting... It's a little hard to read the scans that you posted. Is the scallop at the 6:00 position on the engine side of the flywheel in my picture indicate that it is for a exterior balance engine such as the 440 heavy rod engines were?That looks to be a 70 -71 130 tooth heavy rod flywheel for a 440 six pack engine .
Pretty sure that is too big to fit a passenger car BH.Mine is a 10.5" 130 tooth wheel.
No, but I will count the teeth tomorrow to be sure.Pretty sure that is too big to fit a passenger car BH.
Have you actually counted the teeth?
I have not seen a casting number, but I will double check.Have you looked it over very closely for a casting number?
Thanks for posting the larger picture. I never noticed those extra two drilled thru hoses.Most all my neutral balanced 10.5 130 tooth flywheels have the scalloped cut. The thing that lets me believe it is a 440 six pack or heavy rod flywheel is the two small balance holes it has drilled completely through as stated on the first page I posted above.
What book is that from? Thank you.Most all my neutral balanced 10.5 130 tooth flywheels have the scalloped cut. The thing that lets me believe it is a 440 six pack or heavy rod flywheel is the two small balance holes it has drilled completely through as stated on the first page I posted above.
