flywheel for a 1973 360
Cerwin
Victoria, Bc.
which 360 vehicles came with a standard trans so i can look up how much a flywheel will cost me...
thanks i found the part number thru work tho..
FW-396
143 teeth
OD = 14.5"
clutch size = 11"
fits clutchs with 11"-12"
318,383,400,440 from 1967-1991
and mines a 73. so bada bing!
This part;
360 Cast Crank - (1971 - 92)
Replacement flywheel for the 360 cast crank engine with external balance. Not SFI approved. Six bolt for 10 1/2" clutch.
$249.95
MOP-P4529110
Is what I purchased some years ago. (About 10 now)
what do you think about a 360 3 speed?
think thats a little wierd?
how would it drive?
Ratios are a bit wide, but I do know a guy that wouldn't have it any other way. HIs was a 73 -74 Cuda, 340 3spd manual. I did have a 318, 3 spd manual Duster once. (Gettin misty eyed allready damn it.)
I noticed 1st gear had to be reved up a tad more than normal.
IMO, it was fine.
The levers would get jammed up once in a while.
