Zelus
Active Member
Hello all!
So, I've got a '73 340 that was balanced, but now has a ruined clutch and (very likely) a burnt flywheel.
What are my odds on having the flywheel resurfaced and maintaining most of the benefit from the balancing?
What sort of limitations are there on resurfacing? I know the engine is on its 4th bore, but I never measured the flywheel before bolting it up.
The issue present that has caused the damage are 2.7 rear end gears, with 24.5 inch tires (18.9 MPG freeway, but absolutely terrible starting out; clutch would slip before tires would).
It was fine in the beginning, as I was only lightly driving it, mostly freeway miles, but now I plan to install a real rear-end (3.55+ gears), replace the clutch, et cetera.
I garaged the car after I realized that I could cause the clutch to slip just by exceeding 4000 RPM.
Thank you!
Thank you!
