Snake
Mopar Nut
Do you fog you engine for winter storage,I have never done this.thoughts please.
Transmission fluid down a running engine does a great job. Get her smoking good and shut her down. I have I nice big spray bottle I use for this job and engine assembly.
This^^^^You can also easily fog the motor using the ported or manifold vacuum sucking from a bottle.marvel mystery oil poured down carb works excellent , might smoke when started, doesn't foul plugs. been using it long time, i pour it down each carb bore, about a cap full, each one, open throttle blades and crank engine over, usually couple revs, then back rocker shafts off,cover carb with towel,good for all winter,, just food for thought
fire her up twice over the winter
