? for Machinist, stroking a used 360..
EL5DEMON340
Aurora,IL
Engine in question was machined 20 years ago, 1973 360, received " machine pkg", bored .030 over, torque plate honed, line honed for ARP studs, zero decked for the H116cp hypereutectic pistons. Been running this internally balanced engine for the last 20 years with stock rotating assembly which i think were .010 under, and floating rod pins, engine has about 15,000 miles on it. Very good running, low 12 second street trim. My goal is to be able to drive 75 miles to the track run 11.50 in street trim (drag radials) 3.55 gears, 71 demon, last run of the day turn up the tune and run very low 11's get kicked out and drive home. Plan on a forged 408 SCAT setup, I have a few 340 blocks but figure if this low mile block can be torque plate honed to run the looser specs of a forged piston, notched and just cleaned I'll be in good shape. Plan on using mild ported J heads, my mechanical 6 pack, tti headers that's on it now. stall is 4,400 9", cam is a 525 lift 242/250 comp solid, looking like a somewhat stock SB. What do you think? thanks.
will probably use stock valve covers, alt, distributor and wires. air cleaner will be the Norms tri power i have been using
I’m not a machinist. But imo if there’s no major wear issues it’s fine.
Low 11’s seems like a tall order for that overall combo.
Carefully inspect the tops of the bores for any ridge.
It’s almost certain the new forged pistons would have the top ring traveling higher in the bore(riding over any ridge that’s there now).
Assuming a race weight in the 3400lb area, the one second improvement you’re proposing will need about 110hp more to get you there.
Hey Mike,
Good to see you're still kicking it with the Demon. It's such a beast! Hope you and the family have been doing well. Hopefully we can get together this season. And holler if you need hand pulling the 360 out etc.
Take care
Hey Mike,
Take care
Hi Pat, doing good... PM me your number my phone died and all was lost!
The clearance should be built into the piston so there should not be a need for a hone for looser specs. That being said, check the bores with a dial bore gauge. J.Rob
