matt71vh
Hello all I have a 4bbl 273 la engine that I pulled from my 4 speed dart. It was running when pulled but burning oil being sucked from the valve guides. When I did a compression test all of the cylinders were above 100psi except #6 I think that it had a bad valve though since the pressure did not go up when I added oil to the cylinder. I have added pics for you to check out. Seen in the pictures but not included is the clutch housing and fly wheel. Also not included is the oil pick up. It will include everything between the oil pump and carb (carter 625cfm) to the balancer and output shaft. I also have some miscellaneous pulleys I will throw in. I am asking $350 for the whole thing but am open to all reasonable CASH offers. I will not go through the hassle to ship it, but I will crane it into your vehicle for you.
Regarding trades, I am interested in bucket seats for my 1966 Dart they do not have to be year or model specific. I am also interested in tires 205/?/14 - 215/?/14, Also complete 8-1/4 or 8-3/4 rear end. After market gauges, body work or ?
