For the '65 guys...build your own Commando!!
Here's a guy on the 'Bay selling a "Commando kit" Just use your good 273-2bbl block, install this "kit" and you got a Commando!!!
Sounds cool!!!
http://cgi.ebay.com/ebaymotors/Plym...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Starting bid: US $400.00
1965 Plymouth Barracuda/Dodge Dart 273 high performance engine package. Includes 4 BBL intake manifold, AFB Carter carb (needs to be rebuilt), Prestolite dual point distributor with points, cap and wires, long duration camshaft and lifters, 10.5 to 1 pistons, chrome air cleaner and finned valve covers with breather and pcv. All parts used in very good condition. Please contact us for more info or pictures.
eBayISAPI.dll
Separately, that stuff would cost a lot more than the starting bid. Maybe someone will get lucky on this and get it for the starting bid.
Although it was missing some stuff like the carb linkage, it was a good deal.
Somebody got it for $300.00. Would you really go to the trouble of installing a used cam and pistons in another block? What are the chances you can find a std. bore 273 block that has doesn't need boring? If course, the intake is only going to work on '64 or '65 model heads. Still, it's a fair deal for the lot.
Mark
