For You Greg...
Killer6
PA
@slant six ,.....I tried attaching this on .org, but file was too large & couldn't be resized;
Thank you.
So is That is a hydraulic listing?
I would guess yes from that -H suffix in the listing#.
Any intake centerline data?
Working on all this for a buddy and if is a hydro cam, then we might have to get another cam.
Thank you.
Yes, both -H suffixes are hydraulics, & -S solids. You could just run it tight-lashed like Shane did in His, He just kept sneakin' up on it 'til it was quiet & started fine, then tweaked it.....forget what the final lashes were. *Edit*: .004" Int./ .006" Exh. for the Hyd. cam He was running.. @dart19666
Lobe separations all 110, no recommended ICL, I assume they figured straight up....maybe +2° on the small ones.
