cfordyce05
- Joined
- Nov 19, 2005
- Messages
- 47
- Reaction score
- 40
Do those of you who have put the Ford 8.8 in, do you just run your wheels as lug centric on the back since it has a smaller diameter register? I'm putting the 8.8 in my car, but I'll also be running the LMR SVE Drift 18x9 wheels on all four corners for a Mustang so the wheels will fit fine on the rear end. I'm debating on whether to machine the hub bores out on all four of the wheels so that they fit in the front as hub centric and then would be lug centric in the rear, or just machine the hubs on the spindles in the front to match the rear end and not machine the wheels. I want to be able to rotate the wheels because I will be running the same tire all around.
