[SOLD] Forged 6-bolt 440 crank
Mopar Mechanical Parts For Sale
Thread Status:
  1. ProSport
    ProSport Well-Known Member
    411
    133
    Mar 30, 2005
    Akron, Ohio
    Local Time:
    8:51 AM
    Contact Seller
    Forged 6-bolt 440 crank, it was all checked out and cleaned up by a machine shop a few years ago, then greased and stood up in a Summit Crankshaft bag for a few years, I just pulled it out for a photo. It comes with the 6 bolts also.
    $125 picked up, $150 shipped.
    I'm around the block from Summit Racing, 44305.
    Photos attached:
  2. dodgewade
    dodgewade Well-Known Member
    48
    1
    Dec 9, 2009
    Local Time:
    2:51 AM
    Straight shift crank?
  3. ProSport
    411
    133
    Mar 30, 2005
    Akron, Ohio
    Local Time:
    8:51 AM
    It was checked for cracks and core shift/straightness, if that's what you mean.
    If not, please clarify and I will look into it.
    Thanks.
  4. JDMopar
    JDMopar Well-Known Member
    4,139
    3084
    Jan 19, 2012
    Candler, NC/Myrtle Beach, SC
    Local Time:
    3:51 AM
    I think he was asking if it is from a 4 spd. car, and drilled for a pilot bushing.
  5. ProSport
    411
    133
    Mar 30, 2005
    Akron, Ohio
    Local Time:
    8:51 AM
    Ok thanks, I don't know a thing about that but if you tell me where to look I will check it out. I can also provide a photo.
  6. duster360
    duster360 Well-Known Member
    3,871
    359
    Aug 8, 2008
    Alabama
    Local Time:
    2:51 AM
    Look on the end of the crank where the 6 bolt flange is. There will be a hole in the center of the crank. If it has ever been used behind a 4 speed transmission there will most likely be a bronze bushing inside the hole.
  7. ProSport
    411
    133
    Mar 30, 2005
    Akron, Ohio
    Local Time:
    8:51 AM
    Does this help?
    I'll check later to see if there's a bushing in there.
  8. duster360
    3,871
    359
    Aug 8, 2008
    Alabama
    Local Time:
    2:51 AM
    I think I see the bushing.
  9. ProSport
    411
    133
    Mar 30, 2005
    Akron, Ohio
    Local Time:
    8:51 AM
    Yes it is, thanks. Price is also negotiable.
  10. duster360
    3,871
    359
    Aug 8, 2008
    Alabama
    Local Time:
    2:51 AM
    Does it have one of these part numbers stamped on it? Should be stamped on one of the counterweights. I think it is usually stamped on one towards the front of the crank.
    2406240
    3751899
    3671242
    3671283
    3512036
    2536983
  11. ProSport
    411
    133
    Mar 30, 2005
    Akron, Ohio
    Local Time:
    8:51 AM
    There's only one place that appears to have had a number but it is not legible at all now.
    Price is negotiable.
Thread Status:
