Formula S (HD) Leaf Springs
The numbers on the bottom of the broadcast sheet are the last digits of the part but not always the part number in the parts catalog but sometimes they are.
From my 68 GTS, rear springs. Part number on the spring leaf is 2835064 and the broadcast sheet calls out 064 but the part book says 3004584
Cliff Ramsdell
Yes I believe if you ordered from the factory a/c the vehicle would come with the 340 torsion bars and even the 5.5" wide steel wheels, even if only a /6 engine.
Bennoel 10, you are incorrect. I had a 69 Dart Custom with AC. Wheels were 4.5, I believe, and the Torsion were also lighter. The wheels I pitched years ago, but kept the bars in case I were to put together a SB drag car.
