project74
So here's the deal. I've just located a 75 Dart Custom out in the countryside. Check this. 8 1/4 rear (open diff), 318/904 combo (not running), full front disc setup and all linkages, wiring, hoses etc. still intact. All this for the huge sum of $800 cdn. Now is it really worth it? Some questions (and the original plan for my Swinger was a V8 swap with all the extras.)
1)Would this 318 be a steel crank motor? i.e. What casting date or number am I looking for? Not sure if the motor rolls by hand or not but even if it doesn't can a seized motor still be rebuilt ok?
2)The rotors and calipers are pretty shot but everything incl. spindles, arms and such is good. Aftermarket rotors and calipers?
3)Not sure of rear end condition and won't be able to check as car has sunk in the weeds. Not that bad to install a sure grip in an 8 1/4 assuming that all else is ok, correct?
All this with a set of big bolt wheels, all glass, tail light assemblies and such. Some of this I'll need anyway. So does this sound like a good deal or someone trying to pawn off a pile of useless, unrebuildable crap. Keep in mind the car is in a wrecking yard and looks to have been sitting no more than 2 yrs or so. Any hints, suggestions or ideas would be greatly appreciated as I don't want to shell out 800 beans and get burned.
Much thanks in advance.
John
John
