340plot
the bushy bush
I have a 71 plymouth scamp that is going to be used as a donor car to build the dart 340. i just picked the car up. it has been off the road since 98, but the p.o has still started it and moved it around. i poured gas in the carb, and she fired right up. the throttle sticks some at the car, but does not leak. the trans i am told is good, but have not verified.
THERE IS A GUY IN NC, THAT WAS LOOKING FOR A /6, SO I WILL TRY AND OFFER IT TO HIM FIRST, BUT ILL GIVE IT TILL TOMMOROW THIS TIME, AND THEN IT IS UP FOR GRABS. YOU MUST HELP ME LOAD IT IN YOUR TRUCK, OR IF YOU WANT TO HEAR IT RUN, YOU MUST STAY AND HELP PULL IT OUT.LOL
