BLOCK IS .030 OVER
CLEANED, BORED, HONED AND LINE HONED
CASTING DATE 12-10-68 (early 69 car)
KB-243-030 HYPEREUTECTIC 68-71 VERSION PISTONS
NEW KIETH BLACK MOLY RINGS
STOCK STEEL CRANK .020/.020
STANDARD 340 BUSHED RODS
NEW SEALED POWER CAM, ROD AND MAIN BEARINGS
NEW BRASS EXPANSION PLUGS
NEW SUMMIT .480/.480 LIFT HYD. CAM & LIFTER KIT #SUM-1798
NEW MELLING HV OIL PUMP AND PICKUP
OEM CAR TYPE OIL PAN
FACTORY STEEL CRANK 340 HARMONIC DAMPER
HUGHES ENGINES TIMING CHAIN SETUP #6442
"J" HEADS WITH OEM 340 HP SPRINGS
FACTORY INSTALLED 2.02/1.6 VALVES
STOCK TYPE ROCKER ARM-PUSHROD SETUP
LATE STYLE TIMING COVER
COMPLETELY ASSEMBLED
PAINTED STREET HEMI ORANGE
$3,000.00
plus shipping from Edison, NJ 08820
Also available is an Edelbrock Torker 340 intake - $100
Chrome valve covers - $30
Remanufactured water pump - $35
OEM HEI distributor and Accel wires - $40
I can also help with shipping arrangements,
crating and delivery to truck terminal for a small fee
Ken
Edison, NJ
$3,000.00
Ken
Edison, NJ
