[SOLD] FRESH 1971 340 SHORT BLOCK ASSEMBLY
physixx
Edison, NJ
BLOCK IS .010 OVER
CLEANED, BORED AND HONED
BLOCK HAS BEEN LINE HONED
CASTING DATE 9-29-71
NEW DIAMOND HIGH COMPRESSION 11.0:1 PISTONS
NEW MOPAR PERFORMANCE FILE FIT MOLY RINGS
OEM STEEL CRANK CUT .010/.010
OEM FULL FLOATING STEEL RODS, NEW BUSHINGS, RESIZED & SHOT PEENED
NEW SPS ROD BOLTS
BALANCED ROTATING ASSEMBLY
NEW CLEVITE CAM, ROD AND MAIN BEARINGS
FACTORY WINDAGE TRAY SETUP
NEW EXPANSION PLUGS
NEW MOPAR PERFORMANCE .557/.557 LIFT SOLID LIFTER CAM & LIFTERS #P4120655
NEW MELLING HV OIL PUMP
NEW CUSTOM DEEP SUMP OIL PAN WITH PICKUP
NEW SFI APPROVED HARMONIC BALANCER
NEW CLOYES TRUE ROLLER TIMING SET #9-3103-5
LATE STYLE TIMING COVER
WILL NOT WORK WITH CLOSED CHAMBER HEADS BECAUSE OF PISTON HEAD DESIGN
COMPLETELY ASSEMBLED & PAINTED HEMI ORANGE
$2,950.00
plus shipping from Edison, NJ 08820
I can also help with shipping arrangements, crating and delivery to truck terminal for a small fee.
