[FOR SALE] Fresh 408 short block or complete engine
hemichuck
Louisville Kentucky
i was digging around looking at my projects and I'm up to my butt in 4 inch stroke motors. It's time to liquidate some of this stuff and buy me a 572 Hemi. This short block is a 1978 360 block that's been bored .030 and honed with a plate. New cam bearings and brass freeze plugs are installed. It has an Eagle forged 4 inch crank with Eagle rods and Probe flat top Pistons with valve notches. It's been internally balanced and has a zero deck. All machine work and assembly was done by Gene Cummins at Auburndale Machine in Louisville. I've got $3600 in it but I will take $3000 for it.
If you want to complete the engine I have a couple of options, I have a brand new unassembled set of W2 heads with the 75cc combustion chambers that would put this motor right around 10.5 compression. I have everything needed to assemble the heads, valves,rocker stands, bushed steel rockers, shafts, valve springs, retainers and locks. Also have a W2 Holley Strip Dominator. Heads are brand new leaving you to do whatever porting work you like. I'll take $2500 for the heads. I also have a new set of Headman Hustler headers for an A body with the plates and gaskets I'll let go with the package for $500. I don't need the money and I don't have to sell it so I don't want to sell individual pieces. If someone just wants the short block, when it's gone I'll sell the head package. I also have a couple of cams to choose from. All located in Louisville Ky.
I'll sell them with the heads or after I sell everything else. If the motor don't sell I'll have to stick it in something.
Are your W2s the 810 (race) castings with single exhaust pattern? Re: the Hedmans. Does the drv side have the one primary that exits through the fenderwell? Thnx.
